    Degrees to compass direction
    Scheduled Pinned Locked Moved Solved REXYGEN Studio
    4 Posts 2 Posters 1.1k Views
      Hi Team,
      I'm using open weather map. Wind direction is in degrees. If I wanted to convert degrees to a compass direction, NNE for example. What's the best way to do that?
        have a look at function block CNDR and PARE - it should do the job. CNDR could be used to transfer range of wind direction to an integer value. Integer could be represented using PARE by number and string (PARE:sy).
          MikeyH @cechurat
          @cechurat Hi Tomas,
          That works very well
          I ended up doing it in intervals of 22.5deg. But used 17 values all together to allow for 0 and 360 = N.
          Thank you for the help.
            Thanks for your feedback - I'm glad I could help.
            Kind Regards.
