    Writing once a single value to a register
    Scheduled Pinned Locked Moved Modbus TCP
    4 Posts 2 Posters 2.8k Views
      Scoobsalamander
      I"m trying to communicate with a Beckhoff BK9000 bus coupler and to reset the watchdog timer I need to send consecutively the values 0xBECF and 0xAFFE to a single register.
      I only want to send this reset command when the watchdog timer elapsed due to some problem....
      I'm not sure if this is possible with Rexygen......
        Hi Scoobsalamander,
        thanks for your question. If I understand correctly the solution can look like:
        Sample source file: Beckhoff_resetWatchdog.mdl
        Hope it helps.
          Scoobsalamander
          Thanks, this is indeed a working solution. I only needed to slow down the messages to 1 per second, which is still fine.
            Hi Scoobsalamander,
            glad I could help. You are right, I didn't take to count the timing. Good luck with your project!
