    Update REXcore etc on Monarco
    Development tools
    745
      I have a Monarco running REXcore 3.0.1 and I'm now using the new 3.0.3 studio. It won't connect, error code-126, which I assume is a compatibility issue.
      Is there a way to update this without a complete reinstall?
        Yes, your assumption is right. Always try to have the same versions both on your PC and on your target device.
        The update process depends on the state of your OS image. If you don't need any fixed version of other packages for some reason, I would perform an upgrade of the whole OS:
        sudo apt upgrade
        If it won't help, you will probably need to change the location of the REXYGEN packages - for more details, see Chapter "Manual installation" in the documentation provided with the 3.0.3 Development tools.
        Let me know if it helps.
        • cechuratC cechurat moved this topic from Monarco HAT on
          That worked thank you, I used apt-get which didn't seem to update the REX stuff.
          Thank you
