    Complier issue
    7
    850
    • H
      har
      I am not sure how to make the stop in the lower right hand corner run
      • cechuratC cechurat moved this topic from Communication (RS232, RS485, I2C, SPI, UDP, TCP, ...) on
        Hi har,
        thanks for your question. Please, can you share System Log? There should be some error which is preventing RexCore from running.
        H 2 Replies Last reply Reply Quote 1
        • H
          har @cechurat
          • H
            har @cechurat
            I think the problem might be in the python block.
            import numpy as np
            import time
            from numpy import sin,cos,pi
            from scipy.integrate import solve_ivp, solve_bvp, quad, odeint
            from scipy.linalg import solve_continuous_are
            from scipy.interpolate import interp1d
            #import matplotlib.pyplot as plt
            from PyRexExt import REX
            def init():
            global ω,ζ,π,τ,τ1,τpred,xmax,umax,θinti,θdotinit,xinit,xdotinit,xstate_init,θend1,θend2,θdotend,xend,xdotend,xstate_end1,xstate_end2,Q,R,ts,dt,ts1,bvpfcn,bcfcn,ff,uff0,uff,runningCost,A,B,mRiccati,Sall,Ball,Kall,fpred,us,j
            global xstate_end,FFsol,X,uff,vs,Kvec,Xlast,Klast
            ############################################ Define parameters
            ω          = REX.u1.v
            ζ          = REX.u2.v;                      # pendulum friction (scaled: 1 = critical damping)
            π          = pi;                            # π = 3.14159...
            τ          = 2*π                            # swingup time = 1 period, in scaled units
            τpred      = 1                              # allow for calculation time, in scaled units
            τ1         = 2*τ                            # for sim: swingup + balance time
            xmax       = 2;                             # track limits at ±xmax
            umax       = 5;                             # clip u for simulation test ONLY (not design)
            θinit      = 0;                             # initial angle of pendulum
            θdotinit   = 0.0;                           # initial angular velocity of pendulum
            xinit      = 0.0;                           # initial position of cart
            xdotinit   = 0.0;                           # initial velocity of cart
            xstate_init = np.array([θinit,θdotinit,xinit,xdotinit])        # eventually, from expt.
            θend1      = π                              # CCW swingup,   assume θinit ∊ (-π,π)
            θend2      = -π                             # CW swingup
            θdotend    = 0.0;                           # final angular velocity of pendulum
            xend       = 0.0 * xmax;                    # final cart position
            xdotend    = 0.0;                           # final cart velocity
            xstate_end1 = np.array([θend1,θdotend,xend,xdotend])   # modify for swing down, transport, ...
            xstate_end2 = np.array([θend2,θdotend,xend,xdotend])   # modify for swing down, transport, ...
            Q    = np.diag([1,10,1,1])                  # weighting for states for LQR
            R    = np.array([10])                       # weighting for input for LQR
            ts   = np.arange(0, τ, 0.01*ω)       # swing up in τ
            dt   = 0.01*ω
            ts1  = np.arange(0, τ1, 0.01*ω)      # swing up in τ, balance for another τ
            ############################################# Define functions
            def bvpfcn(t, X):                           # solve coupled state-adjoint system
                θ, θdot, x, xdot, λθ, λθdot, λx, λxdot = X
                dX = np.zeros((8, X.shape[1]))          # array dimension is 8 * nx
                sinθ = sin(θ);  cosθ = cos(θ)
                u = -λxdot + λθdot*cosθ
                dX[0] = θdot
                dX[1] = -sinθ - u*cosθ
                dX[2] = xdot
                dX[3] = u
                dX[4] = λθdot * (cosθ - u*sinθ)
                dX[5] = - λθ
                # dX[6] = -x**3 / xmax**4                 # or:  from running cost term (x/xmax)**4
                dX[6] = 0                               # running cost independent of x
                dX[7] = -λx
                return dX                               # Return derivatives (array)
            def bcfcn(x0, xτ):                          # boundary conditions for 4d-state at t = 0, τ
                dx0 = x0[0:4] - xstate_init             # boundary condition for 4d state at t=0
                dxτ = xτ[0:4] - xstate_end              # bc                              at t=τ
                return np.hstack((dx0,dxτ))             # 8-dim vector for solve_bvp
            def ff(x0,xτ,τ):                            # ff state x0 → xτ in τ
                θinit,_,xinit,_ = x0
                θend, _,xend, _ = xτ
                nt = 21                                            # number of time points, to start
                tvec = np.linspace(0, τ, nt)
                xλguess = np.zeros((8, nt))                        # initial guesses for state trajectories
                xλguess[0, :] = np.linspace(θinit, θend, num=nt)   # θ linear, θinit → θend
                xλguess[2, :] = np.linspace(xinit, xend, num=nt)   # x linear, xinit → xend
                FFsol = solve_bvp(bvpfcn, bcfcn, tvec, xλguess, tol=0.1)   # solve boundary-value problem
                return FFsol.sol
            def uff0(t):                                # feedforward acceleration (cannot evaluate on arrays)
                θ,_,_,_,_,λθdot,_,λxdot = FFsol(t)      # evaluate interp funcs at time=t
                uff0 = -λxdot + λθdot*cos(θ) if t<τ else 0
                return uff0
            uff = np.vectorize(uff0)                    # define vectorized version (can call with array)
            def runningCost(t):                         # to calc cost of the feedforward command
                return 0.5*uff0(t)**2
            def A(t):                                   # dynamical matrix (local linear, nominal)
                θ         = FFsol(t)[0]                 # FFsol from FF function
                Amat      = np.zeros((4,4))             # 4 is from xstate.shape[0]
                Amat[0,1] = 1
                Amat[1,0] = -cos(θ) + uff(t)*sin(θ)
                Amat[1,1] = 0
                Amat[2,3] = 1
                return Amat                             # evaluated at time t
            def B(t):                                   # input vector (local linear, nominal)
                Bmat    = np.zeros((4,1))               # 4 is from xstate.shape[0]
                Bmat[1] = -cos(θ)
                Bmat[3] = 1
                return Bmat
            def mRiccati(t,S):                          # derivatives for matrix Riccati (vector form)
                Smat = S.reshape((4,4))                 # convert 16 vector to 4x4 matrix
                A0 = A(t)                               # current dynamical matrix
                B0 = B(t)                               # current input vector
                dSmat = - A0.T @ Smat - Smat @ A0 - Q + Smat @ (B0 @ B0.T) @ Smat / R[0]
                dS = dSmat.reshape((16))                # convert 4x4 matrix to 16 vector
                return dS
            def Sall(Send,τ,tvec):                      # S matrix evaluated at times tvec
                Send1 = Send.reshape((16))
                t_span = (τ, 0)                         # solve backwards in time, from τ → 0
                Ssol1 = solve_ivp(mRiccati, t_span, Send1, dense_output=True).sol
                return Ssol1(tvec).reshape(4,4,tvec.size)   # evaluate on tvec
            def Ball(FFsol,tvec):                       # input matrix (local linear, nominal)
                θ       = FFsol(tvec)[0]
                nt      = tvec.size
                Bmat    = np.zeros((4,nt))              # 4 is from xstate.shape[0]
                Bmat[1] = -cos(θ)
                Bmat[3] = np.ones((nt))
                return Bmat
            def Kall(Send,FFsol,τ,tvec):                # for graphing
                tvec1 = np.clip(tvec, 0, τ)             # elements beyond ff range are clipped to limits
                S = Sall(Send,τ,tvec1)                  # 4 x 4 x nt matrix (nt copies of 4x4 matrix
                B = Ball(FFsol,tvec1)                   # 4 x nt matrix     (nt copies of 4-vector)
                return np.einsum('ijk,jk->ik', S, B)/R[0]   # sum over inner index, element-mult tvec index
            def fpred(t,xstate):                        # dynamical eqs, for constant-v input
                θ, θdot, _, xdot = xstate               # dynamical states
                dX = np.zeros((4))                      # 4 is from xstate.shape[0]
                dX[0] = θdot
                dX[1] = -sin(θ) - 2*ζ*θdot              # sim has pendulum friction, even if ff does not
                dX[2] = xdot
                dX[3] = 0                               # driving term is vtot; utot is a derived variable
                return dX
            ############################################# prediction of future state
            xpred  = solve_ivp(fpred, (0, τpred), xstate_init, dense_output=True).sol # predict future state
            xstate_init  = xpred(τpred)                 # "initial" state, as predicted τpred in future
            θ0 = xstate_init[0];                        # extrapolated θ0 might not be ∊ (-π,π)
            θ1 = (θ0+π) % (2*π) - π                     # modulus 2π
            xstate_init[0] = θ1                         # new angle is ∊ (-π,π)
            ############################################# FF calculations
            xstate_end = xstate_end1; θend = θend1
            FFsol  = ff(xstate_init,xstate_end,τ)       # ff solution for 4-state and 4-adjoint, 0→τ
            FFsol1 = FFsol
            Jff1   = 0.5*np.sum(uff(ts)**2)*dt          # integrated running cost = overall cost
            xstate_end = xstate_end2; θend = θend2
            FFsol2 = FFsol
            Jff2   = 0.5*np.sum(uff(ts)**2)*dt          # integrated running cost = overall cost
            REX.y11.v = f"feedforward cost: θend = π, Jff1 = {Jff1:0.2f}, θend = -π, Jff2 = {Jff2:0.2f}"
            if (Jff1 < Jff2):
                FFsol = FFsol1;   xstate_end = xstate_end1
            else:
                FFsol = FFsol2;   xstate_end = xstate_end2
            ############################################### fb calculations
            Aend = A(τ)                                   # linear dynamics A matrix at t=τ
            Bend = B(τ)                                   # linear input-coupling B vector at t=τ
            Send = solve_continuous_are(Aend,Bend,Q,R)    # static S matrix from ARE
            Kvec = Kall(Send,FFsol,τ,ts1)                 # feedback gain vectors for t in ts1
            ############################################### get arrays
            θs,θdot,x, xdot,_,_,_,_ = FFsol(ts)
            X = np.array([θs,θdot,x,xdot])
            θlast,θdotlast,xlast,xdotlast,_,_,_,_=FFsol(2*π)                # Evaluate last values
            Xlast   = np.array([[θlast],[θdotlast],[xlast],[xdotlast]])
            X       = np.hstack((X,Xlast))                                  # add last value
            Klast   = Kall(Send,FFsol,τ,2*π+0.1)
            Kvec    = np.hstack((Kvec,Klast))
            vs      = np.hstack((xdot,0))
            j=0
            def main():
            start_test = time.perf_counter()
            global j,X,uff,vs,Kvec
            if not REX.u0.v and j == 0:
                return
            else: REX.y15.v = True
            REX.y10.v= f"len(X)={len(X[0])}"
            if (j >= len(X[0])):
                REX.y8.v = 0
                return
            # Value for every time
            REX.y0.v = X[0][j]
            REX.y1.v = X[1][j]
            REX.y2.v = X[2][j]
            REX.y3.v = X[3][j]
            REX.y4.v = Kvec[0][j]
            REX.y5.v = Kvec[1][j]
            REX.y6.v = Kvec[2][j]
            REX.y7.v = Kvec[3][j]
            REX.y8.v = vs[j]
            j += 1
            test_time = time.perf_counter() - start_test
            REX.y9.v = f"test time = {test_time:0.3f} s"
            return
            def exit():
            # PUT YOUR CODE HERE
            return
              cechurat @har
              @har Yes, the issue is in initialisation of the Python Block. If you wait a second with the mouse on the message 377b94ec-fd02-467a-985c-a0611d9455ba-image.png
              it will show you more instead of "..." which might help you to find the issue easier.
              H 1 Reply Last reply Reply Quote 0
              • H
                har @cechurat
                @cechurat Hi Thomas when I hover my mouse over the error I get this message.
                I am not quite sure what it means or how to fix it
                  cechurat @har
                  @har Hi har,
                  Thanks for the additional info. We are not able to provide free support on this since it's your custom Python script. The error is not related to the Rexygen ecosystem. It seems that the CPU dispatcher is being initialised multiple times.
