    License error
    Scheduled Pinned Locked Moved General
    5 Posts 3 Posters 702 Views
      Any reason I have suddenly started to get this error
      I have all the licenses required, this monarco has been running fine and today suddenly it's not once a new version of the algorithum was uploaded. These are the licenses on the monarco.
      this is the complirer log
      Any ideas?
        Jan Reitinger @MikeyH
        Hi @MikeyH ,
        The error "Configuration requires higher license than available on the target device" is caused by having an old license version with the new REXYGEN.
        This error does not prevent the algorithm from running – your System Log confirms it started successfully.
        The real issue is the Modbus communication failure with your slave device. Could anything have changed on the slave device side recently?
          MikeyH @Jan Reitinger
          @Jan-Reitinger Hi Jan,
          Thanks for clearign that up.
          I'm not sure what happened with the slave device, it hasn't been changed at all, a mystery! If I find the issue I'll le you know.
          S 2 Replies Last reply Reply Quote 0
            sharonmartin1 @MikeyH
            Thanks for the clarification, Good to know the license message isn’t preventing the algorithm from running.
            I’ll check the Modbus slave and communication settings again and see if I can find what changed. I’ll update the thread if I figure it out.
