    HMI and Subsystem Mask
    832
      If I have a CNR block in a subsystem, that I am using in a subsystem mask to give say a set point value. Can you still write a value to that CNR block via the HMI?
        in such a case you should write the value from HMI to the subsystem mask, from where it will propagate to the corresponding CNR block. The connection string will be
        yourtask.subsystem:parameter
        Hope this helps, let me know.
          Thank you for the help. I will give that a go and let you know what happens.
