Modbus : converting data from two registers into float
Wish you happy new year to team and users !
I have some dificulties to convert the modbus data from a device (here a mass flow).
I retrieve the data, but i need to convert it.
Here the configuration :- Reading holding register (3)
- quantity : 2 (u16)
I need a 32-bit float (SGL) after the conversion.
I tried different configuration but without success.
May be need some Swap before join ?Thanks for your help
Emmanuel.
Hi Emmanuel,
thanks for your question. Can you share configuration of Modbus in your project (or preferably whole REXYGEN project if possible) so I can have a look at the settings you used?
There is possibility to Swap Bytes or Swap Words at each Modbus item - did you try that?
Thanks Thomas
I'll try these parameters.PS : later, cause a collegue take my device...
