    Modbus : converting data from two registers into float
    1.3k
      bigmanvstrashman
      Wish you happy new year to team and users !
      I have some dificulties to convert the modbus data from a device (here a mass flow).
      I retrieve the data, but i need to convert it.
      Here the configuration :
      • Reading holding register (3)
      • quantity : 2 (u16)
      I need a 32-bit float (SGL) after the conversion.
      I tried different configuration but without success.
      May be need some Swap before join ?
      Thanks for your help
      Emmanuel.
        Hi Emmanuel,
        thanks for your question. Can you share configuration of Modbus in your project (or preferably whole REXYGEN project if possible) so I can have a look at the settings you used?
        There is possibility to Swap Bytes or Swap Words at each Modbus item - did you try that?
          bigmanvstrashman
          Thanks Thomas
          I'll try these parameters.
          PS : later, cause a collegue take my device...
