    Installation of REXYGEN 2.50.10-testing
    Development tools
    10
    9.8k
      Hello, there is REXYGEN pre-release version 2.50.10-r5 available for testing. For upgrading REXYGEN on your Raspberry Pi please follow the instructions:
      • change the source for the APT packaging system:
      sudo nano /etc/apt/sources.list.d/rexcontrols.list
      replace the contents with:
      deb http://download.rexcontrols.cz/repositories/debian-rex-2.50-testing/ buster non-free
      Save and exit.
      • Update packages cache:
      • Uninstall REXYGEN runtime modules:
      sudo apt purge rexygen-runtime
      sudo apt autoremove
      • Install the newest REXYGEN runtime modules:
      sudo apt install rexygen-runtime
      • As for the newest development tools for your PC, please download the installer from http://download.rexcontrols.com/rex/2.50-testing/windows/
      Note: the instructions assume that you are using Raspbian Buster or newest Raspberry OS. If not, please upgrade your system.
      R 2 Replies Last reply Reply Quote 0
        RexPeter @cechurat
        I just tried to update a Raspberry to the r5 release, but get this problem:
        So I cannot get to the newest release right now. I did updated a few others without problems some time back.
        I will try another time again, maybe problem with server now?
          admin
          Hi, Peter.
          The repository for the release candidate has been replaced with a testing repository.
          Please change the -r5 section of the URL address to -testing.
          Best Regards,
          Jiri
            RexPeter @admin
            Thanks a lot Jiri!
            I will give it a trial.
              RexPeter @RexPeter
              Hi Jiri,
              Just change the url as below:
              Saved the file and tried it again.
              So this still does not work....
                Hi Peter,
                sorry for difficulties with REXYGEN upgrade. The address of repositories is:
                Let me know if it worked for you.
                  RexPeter @cechurat
                  <snip>
                  • As for the newest development tools for your PC, please download the installer from http://download.rexcontrols.com/rex/2.50.10-r5/windows/REXYGEN-2.50.10.12237-x64.exe
                  It appears that also this link is no longer there and need to be updated as well.
                    Hi Peter,
                    sorry for difficulties once again. The situation is changing quickly before the actual release. Please, use following link to download the development tools:
                    Thanks for understanding.
                    • gninausG
                      gninaus
                      Hi, How to install the official version. Made a fresh buster installation and followed the standard procedure of the REXYGEN getting started description. But the install was 2.50.9. Or is there still only the testing version released?
                        Hi Guenther,
                        the official release version is still 2.50.9 for now. However we are not far from public release of 2.50.10 and the pre-release version is available in above mentioned post.
