    Energy Meter kwh Reset
    Scheduled Pinned Locked Moved Solved REXYGEN Studio
    7 Posts 3 Posters 1.9k Views
      I have an energy meter I am using, connected via Modbus. The issue I have is the kwh figure in the meter can not be reset to zero, currently it is up to 9124.0 kwh. When I start a new test I'd like to reset the logged kwh figure.
      What is the best way of doing this via the REX program? I wondered about saving the last know value from the Modbus register and then subtracting that to give me a virtual reset and start from zero again.
      Thoughts?
        reitinge @MikeyH
        @mikeyh Hi Mike,
        one possibility is to use a SHLD block with Triggered sampling mode (documentation here). When you send a pulse to the block input SETH, the current value of input u is stored at output y. The overall connection can then look something like this:
          MikeyH @reitinge
          @reitinge Hi Jan,
          That works extremely well, even better once made into a small subsystem! Thank you for your help as always.
          A R 2 Replies Last reply Reply Quote 0
            Apollo @MikeyH
            @mikeyh
            Maybe you can also make the parameters of function block SHLD non-volatile (Persistent parameters).
            If you restart your computer and/or download new program then it will not lose the previous stored value.
            And storing the value every midnight in a database and then trigger the SETH input would give you a nice overview of the daily consumption.
              reitinge @MikeyH
              Hi guys,
              @mikeyh you're welcome. @apollo is right with persistent parameters. If you don't just do short-term tests, don't forget to turn persistent parameters on.
              M 2 Replies Last reply Reply Quote 0
                MikeyH @reitinge
                  MikeyH @reitinge
                  Hi Both,
                  Thank you. @Apollo, great tip. That will save me loosing data.
