    Cooling and Heating
    5
    2.0k
      I’m trying to put together some control logic to both cool and heat using a dead band. Currently I’m using a CMP block for cooling, this works really well. Now need to add heating to this. I was think about using two relay blocks but I’m sure there is a better way.
      Thoughts?
        how about using the PWM block?
        If u=-1, then UP will be ON and you can use it for heating. If u=0 then both outputs are off. And if u=-1 then DN will be ON and you can use it for cooling.
        The PWM:offtime parameter defines the minimum delay between heating and cooling phases.
        Let me know.
        Kind regards
          Hi Jaroslav,
          What would work but wouldn't I then have to use a PIDU block (or similar) for the main process control? I don't need the accuracy of a PID controller.
          This is my current cooling solution.
          I'm guessing keeping it simple now I require heating isn't so easy 🙂 Other people need use this after myself so I trying to not over complicate it. But if I need to then I will, no problem.
            I see. In that case the simplest approach is to use the TSE block (three state element), which moreorless combines two comparators with hysteresis.
            Kind regards
            • B
              Beauvais Banned
              This post is deleted!
