    HMI Designer 3.2.5
    16 Posts 3 Posters 2.9k Views
      MikeyH @MikeyH
      I can connect and select the path etc
      I then get the parsed error
      It's a bit different than I remember and I can't seem to export the HMI svg etc, has that changed?
        MikeyH @MikeyH
        ok I've got it exported, now. I just synced the project compile with the HMI designer open and it worked. But now the TRND graph doesn't show the data. If does briefly when changing the time line.
        It works if I give the Y axis a min/max range, but i though it would auto adjust?
          MikeyH @MikeyH
          I'm also getting this for the logger too, but can't work out why, any ideas?
            @MikeyH Hi Mike!
            Do you use the same versions of Development tools and REXYGEN Runtime?
            The TRND not providing any data seems to be disabled - is it active in the running project?
            The error message about parsing the output can be omitted - the extension returns something which throws this error. It won't affect the behaviour of the HMI. We will try to fix it. Can you share your source files with us?
              My versions are below.
              The parse error has gone now. What seems to happen now is after I set the connect strings in the HMI configuration, it doesn't save them so are always blank when I open it again.
              Thanks for your help with this
                Thanks for reporting this. This is really weird. Please, can you record and share your screen? E.g. using online tool https://gifcap.dev/
                  I will try and record this this week, sorry for the delay.
                    MikeyH @MikeyH
                    Sorry fo rthe huge delay in this! Things happned.
                    Do you know why this was happening in the end?
                      I'm not sure about this specific issue but we have already moved forward with native Inkscape integration of REXYGEN component.
                      Can you try out REXYGEN HMI Designer version 3.4.5? You can get it here: https://download.rexcontrols.cz/partner/daily/rexygen/hmidesigner/signed/
                        I have it downloaded, how do I use this version? I can't see any extensions like previous versions or any way to link it to REX
                          Sorry, I forgot to mention one important thing: In your current REXYGEN installation, open the file C:\Program Files\REX Controls\REXYGEN 3.0.X.YYYYY\HmiDesigner\version.req and change its contents to 3.4.
                          The new HMI Designer requires REXYGEN v3 (I recommend using the latest available 3.0.5)
                          Then the Studio should automatically use the new HMI Designer. You can check it in the compile log after you compile any project with HMI.
                            Should HMI designer be opened from the tray monitor or via the HMI design program it self?
                            I still can't see the REXYGEN extension, or does this version work differently?
                              Dear @MikeyH ,
                              if you open directly the HmiDesigner from C:\Program Files\REX Controls\HmiDesigner 3.2.5\bin\HmiDesigner.exe you will not see any extensions.
                              You have to use the HmiDesigner.exe from the REXYGEN installation e.g., C:\Program Files\REX Controls\REXYGEN 3.0.6.17802\HmiDesigner\HmiDesigner.exe
                              This is also the way TrayMonitor opens the program. If you have any file association for *.svg, check whether it uses HmiDesigner.exe in the REXYGEN folder.
                              This is a known limitation, and we will try to solve it in a future version.
